I'm having issues with installing gnome tweaks both from the terminal and software center. It says, "The following packages have unmet dependencies". Anyone have a solution for this?
If using Zorin OS CORE:
Please open Software & Updates and ensure that on the first tab, Download From is set to "Main Server."
Close it out.
Open terminal and run
Once done, run:
sudo apt update && sudo apt install gnome-tweaks
If using Zorin OS LITE:
You do not need Gnome Tweak Tool. Lite comes with all of that included in the xfce4-settings-manager
what is the full output of sudo apt update? (You can use pastebin to post it, if you prefer.)
I'm trying to repeat the steps above so I can show you the full output but now I'm facing another bug. The Software & Updates menu where I selected "Main Server" is no longer showing up, no matter what I do.
software-properties-gtk
to launch Software & Updates
Um...
I think there are bad sectors on your drive... Because your installation of Zorin OS is showing signs of heavy corruption.
Should I consider reinstalling?
Absolutely.
