Issue with discord related to node.js
So, I had recently to reinstall ZorinOS.
But since, my discord has a messy situation: When I try to access to « Linux parameters » in settings, the app instant crashes and this messages appears:
It seems so that node.js has an issue or is not installed or what when I try to understand the message lol.
Btw I've tried with the flatpack, .dev and .tar-rz version they all have the issue sadly
Maybe a bug of Discord? Here is reported the same in Cachy OS and Linux Mint, but no solution found yet:
Did You uninstalled one Version before trying the next?
Yeah I did. And cleared the cache to be sure
(Btw Leon thank you for your work always answering to everybody, sorry that I call often for bug stuff lol, good luck to you)
I guess it could be a bug since I noticed the flatpack has been updated recently. I've reported it to discord but no answer since
At least so it seems to be a discord issue more than a zorin os/ubuntu/gnome/node.js issue
And when You download and use the .deb Version it behaves the same?
Yeah it does. I'm currently on it rn after a complete reboot and stuff
And the Flatpak Version is uninstalled, yes? Okay, then try flatpak uninstall --delete-data
I apparently just had firefox detected from this command
This post can be closed. Discord has uploaded a fix.
Flatpack, .deb versions both tested and correctly had the bug not happen :slight_smile:
Okay, I marked the Post as Solution.
