Issue with NordVPN on Zorin OS 18.1 Pro
NordVPN (5.4.0) will connect but not allow internet access. Downdetector comments indicates that it appears to be an issue with a kernel update. Any idea when this will get fixed?
Looks Like NordVPN has the action and will provide a fix in NordVPN 6.0.0.
Interim fixes include:
(a) Kernel rollback
(b) Override DNSSEC - sudo resolvectl dnssec nordlynx off
(c) Uninstall, reboot and reinstall of NordVPN (this worked for me).
Hello and welcome to the forum,
I came across a bug reported on 11 October 2026 whilst searching online:
(Linux Mint 22.3, like Zorin 18, is based on Ubuntu 24.04)
To check whether it is present on your system, run the following command:
journalctl -u systemd-resolved --since "1 hour ago" | grep -i dnssec
You should see errors such as DNSSEC validation failed: missing-key or incompatible-server
Also check the status of the interface:
resolvectl status nordlynx
You will probably see DNSSEC=allow-downgrade/supported which triggers the DNSSEC validation, which fails silently.
Restoring the kernel is unnecessary
Immediate solution
This restores internet access straight away. It is a temporary fix.
Permanent solution
NordVPN is preparing version 6.0.0 with a permanent fix. Install version 6.0.0 as soon as it is released,
then re-enable DNSSEC:
sudo resolvectl dnssec nordlynx allow-downgrade
I hope this helps :grinning_face:
I ended up uninstalling then reinstalling NordVPN. That ended up working for me, at least for now.
