[Issue] ZapZap graphical corruption after waking from hibernation (NVIDIA RTX 3060)
Hi everyone,
I am experiencing a persistent graphical glitch with ZapZap (WhatsApp client) on my laptop.
The Issue: Every time I close the lid of my laptop (triggering hibernation/suspend) and then unlock it again, the ZapZap window glitches out completely. As seen in the attached screenshot, the background turns black, and the contact list becomes a corrupted white block with green circles.
The app is unresponsive to UI updates until I restart it. Other applications seem to work fine, but ZapZap breaks consistently after every lid close.
My System:
  • OS: Zorin OS 18 Core
  • Device: Lenovo Legion 5 Gen 6 (17.3" FullHD 144Hz)
  • CPU: Intel Core i7-11800H
  • RAM: 16GB
  • GPU: NVIDIA GeForce RTX 3060 (6GB)
  • Storage: 1TB SSD
What I have tried so far: I suspected this was related to the NVIDIA drivers or GPU rendering, so I tried the following within ZapZap's settings:
  1. Disabling "GPU Hardware Acceleration".
  2. Enabling "Single process for GPU and rendering".
Unfortunately, neither of these settings solved the problem; the artifacting persists immediately after waking the laptop.
Suspicions: I suspect this is an issue with how the NVIDIA driver handles the Electron container during power state transitions, but I am not sure how to fix it at the system level or if there is a specific launch flag I should be using.
Has anyone experienced this with ZapZap or other Electron apps on Zorin with NVIDIA hardware?
Any advice would be appreciated!
Does this happen when You go manually in suspend, too? you could take a Look at this:
Because You have an Nvidia Card: Does Your System run in Wayland or X11? You can check that in Settings>About.
Hi @Ponce-De-Leon !
Yes, the glitch happens when I manually suspend it too.
I installed dconf-editor and I changed both lid-close-ac-action and lid-close-battery-action to 'blank', I saved the changes, I rebooted, yet the ZapZap graphical corruption keeps happening.
My system runs on X11, which I thought was already a thing of the past.
Many OS developers, would like to lead people to believe, that X11 is a thing of the past, because their goal is to push Wayland. Wayland, is far from being ready in modern times, its loaded in bugs, and doesn't work for 99% of Linux users, especially those who have Nvidia GPU's like myself.
Since I couldn't think of anything else, other then disabling power saving features in the OS, I asked Google AI, and this was the response...
I guess You have installed it in Gnome Software as Flatpak? I saw that thre is an AppImage available on the Github Page. You could try this instead:
Hi, thanks for proposing the AppImage, however the same glitch happens with it :frowning:
You could try a different Program to check if it happens there, too. I'm not very in to this but I saw there 2 Programs called Karere and Whatsie.
Thank you for your reply, I'm not motivated to try more apps at this moment, but I will keep it mind. The problem persists.
