Referencing: How to install Zoom - sole edit by moderator
After the step 2 the answer is “No se encontro ninguna aplicacion”.
Hi fvillavi,
If you are having issues getting Zoom to work there is a very good alterntative that does not require any installation, just a browser that supports Chrome extensions like Chromium, Brave Browser or Waterfox or Vivaldi.
Just go to https://meet.jit.si/ create an obscure named room, invite friends and family but not before making up a sentence password, no gaps but capitals at start of new word in sentence then either send a text or email with the link to family/friends. If you want to build your own jitsi server (too complicated for me) the instructions are here:
https://www.brring.com/2020/04/04/setting-up-a-jitsi-server-in-less-than-15-minutes/
Other methods of communication often overlooked: Linphone - but will now need to start a separate security thread!
Search just "zoom".
Buscar sólo para "zoom".
NOTE: The Software channel version is a Flatpack. If you prefer a .deb or local build:
wget -O /tmp/zoom.deb https://zoom.us/client/latest/zoom_amd64.deb
sudo apt update && sudo apt install libxcb-xtest0
You may need:
sudo apt-get install libegl1-mesa
Then:
sudo dpkg -i /tmp/zoom.deb
Sorry I forget to say that my laptop is a Toshiba 32 bits.
That is important information. ![]()
In that case, please download the key:
https://zoom.us/linux/download/pubkey
Download the Ubuntu 32bit package from the Zoom site here:
In terminal, run
cd ~/Downloads
sudo dpkg -i zoom_i386.deb
I changed to _i386 and it worked. Ok
