Issues mounting HDD ExFat between 2 Zorin Accounts
Dear All,
I'm having issues on making a second HDD work between 2 Zorin accounts, one is a limited account I use for daily use, another Administrator status only to change system parameters and install some apps.
Well, I have used the "Disks" app to mount the HDD, which is formatted to ExFAT instead of NTFS, because ExFAT is more compatible, if I login to my main account, I can't get access to the ExFAT HDD on my Administrator account, the same happens otherwise, it seems the first account that mounts the second HDD, gets hold of it, and won't let go, unless I reboot the system, which is weird.
On the mounting options, I have added these parameters.
gid=1000,uid=1000,nodev,nofail,x-gvfs-show,nobootwait
Also is worth noting, when booting, the second HDD doesn't automatically mounts, unless I boot the "Files" app, which is another thing weird.
Is there a solution to this issue?
Thanks
337harvey,
Thanks, added the group sudo to my limited account, it can now mount HDD, but it doesn't auto mount whenever the computer boots. However when I go to my administrator account, since HDD was mounted on the other account, still can't get access to it, as per image
This is so weird
Thanks again for your reply, the HDD is brand new, is only a week old, actually I use dual boot and on Windows I have zero issues, also another distro, mint, never had any issues either, I guess is something in Zorin.
I selected defaults settings on "Disks" apps, only added the option nobootwait to mount on boot, and now I get this error, the error depends on the parameters on the mounting
Thanks , going to study that explanation
Already found an easier way to fix this issue, firstly ran
lsblk
to see the available partitions, and then created a startup application, with udisksctl, which forces mounting, and now whenever the computer boots I have the HDD available :grinning:
udisksctl mount -b /dev/sdb1
Now I have a fully working Zorin with no issues, this distro is so beautiful and modern.
