Issues with my earbuds' sound quality
Hey Everyone.
Sometimes, when I connect my earbuds to my laptop, somehow, the sound is so noisy and terrible. I have to disconnect it some times until in the audio settings, another option appears in output section, and I need to choose between (Headset - R50i soundcore) and (Handsfree - R50i soundcore), and (Headset) works perfectly fine and the other is terrible.
How can I fix that?
You could try adjust it with Easyeffect application.
When ''Headset'' works fine, You could stay on that.
well, whenever I restart my laptop, it automatically resets to (Handsfree).
In that case, I have to turn the bluetooth on and off some times, beside putting and taking the earbuds in/from the case.
so annoying.
well I actually did;
and it didn't help at all!
whenever I restart my laptop, the settings reset to the previous state (I guess I can call it the default settings).
even in easy effect app I can't find the (Headset) option unless I try turning on/off the bluetooth and taking/putting the earbuds from/in its case.
Then try the Following: Install Pulse Audio Volume Control. It is a Tool for set up Audio Input and Output. You can install it with sudo apt install pavucontrol
When installed, open it and take a Look at the Configuration and Output Tab for Your Earbuds and set up the Audio Profile.
