Issues with vim syntax highlighting and position remembering
On some systems the vim syntax highlighting works as expected. But on my Zorin 18 laptop it doesn't do highlighting at all, nomatter what I do. Google search said I need to add a line to the ~/.vimrc file but on other systems where it works that file doesn't exist. And I think it is related but the position memory (where it returns you to the line you were on when you last edited a file) isn't working either - it just always goes to the start of the file.
Anyone have any clues?
Maybe try a Reinstall: sudo apt reinstall vim
Did You tried it with this mentioned Config File?
That did the trick. Thanks!
