Hello.
Here is my history using Zorin. My pc is gaming. Today installed Zorin xfce to hope a pc will working better on new hard disk.
Sadly after near 1hour and 30 min system crashed and i get black screen.
I gived many times a chance Zorin to working on my pc but without success.
What i have opened when it crashed. Vivaldi browser,spotify and a game warframe on steam.
With 16 GB ram and gpu with 8GB ram 256 bit, where a game is old from 2013 i don't understand why it crashed.
Processor also isn't poor.
Anyone have some idea?
After changing my hard disk and installing Zorin my observation is faster start software and no freeze if spotify working and music working when game loading, before was some annoying pause.
Zorin working perfectly also on old computers what i tested.
Why damm it happens here? Something wrong with drivers?
Working on Windows but linux is better. Then why i get black screen?
I reading in bios setting only UEFI not legacy and security disabled was all time only changed now for UEFI. After start linux my spotify starting freezing with music. So it could be a hard disk ssd conflict?
If it is conflict old 5 years ssd then if i created a backup partition it also copy bad sectors when i will forward to new hard disk ssd?
Also, it would be great to see what your system logs when the crash happens... Can you please attach your /var/log/kern.log file?
(FYI: It does contain detailed kernel log: HW detection of your system, HW errors, some other runtime information. It shows in details your HW configuration from current boot as well as previous boots [we want to check the crash in your past boots, if anything is logged there by your hardware/drivers] . It does not log/show your debit card numbers or you P*rnhub(TM) profile )
You do not need to create an account- you can use it as a Guest.
Paste your content, then scroll down to the options- when finished with any options, click "Create new Paste"
You have exceeded the maximum paste size of 512 kilobytes per paste. PRO users don't have this limit!
From terminal when put your advice. Something going wrong?
install --directory /usr/bin
install --mode=a+x src/dpm-query /usr/bin/dpm-query
install --directory /etc/dpm-query
install src/dpm.cfg /etc/dpm-query/dpm.cfg
This i have after return what next?
Still is something wrong with all this application. They showing wrong parameters hardware. That could be a problem correct working peripherals hardware. Operating system could be a good but if some software working fail then all system could be unstable.
