Hi,
I use Zorin OS 18 Core. I installed it yesterday. My issue is that it takes time for my laptop to connect to Wifi. Sometimes it takes 5 minutes or more for wifi to connect. Please help. Thanks
Please list your system specs. What computer and model you have?
Or, you could screenshot your Neofetch results and post here.
CTL - ALT - T to enter terminal.
sudo apt install neofetch
neofetch
Additionally, another thing you can, is post the results of your WIFI results too.
sudo lshw -class network
Did You take a Look in the ''Additional Drivers'' Tab if there might be a Driver offered for Your Wifi?
Are Secure Boot and Fast Boot in BIOS disabled? If Windows is still installed: Is Fast Start-Up in Windows disabled?
Does You System run in Wayland or X11? You can check that in Settings>System>Info>Systemdetails
Please post the terminal output of
sudo lshw -C network
