When I run sudo apt update
, it outputs:
~ ▓▒░ sudo apt update ░▒▓ ✔ at 10:06:24
[sudo] password for nicolo:
Get:1 http://it.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://packages.microsoft.com/repos/code stable InRelease
Hit:4 http://repository.spotify.com stable InRelease
Hit:5 http://ppa.launchpad.net/aravisian/gtk-theming/ubuntu focal InRelease
Hit:6 https://dl.google.com/linux/chrome/deb stable InRelease
Get:7 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:8 http://it.archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Hit:9 http://ppa.launchpad.net/zorinos/apps/ubuntu focal InRelease
Hit:10 http://ppa.launchpad.net/zorinos/drivers/ubuntu focal InRelease
Hit:11 http://ppa.launchpad.net/zorinos/patches/ubuntu focal InRelease
Hit:12 http://ppa.launchpad.net/zorinos/stable/ubuntu focal InRelease
Get:13 https://packages.zorinos.com/stable focal InRelease [9.406 B]
Hit:14 https://repo.steampowered.com/steam stable InRelease
Get:15 https://packages.zorinos.com/patches focal InRelease [15,5 kB]
Get:16 https://packages.zorinos.com/apps focal InRelease [9.404 B]
Get:17 http://it.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [2.570 kB]
Get:18 https://packages.zorinos.com/drivers focal InRelease [18,2 kB]
E: Repository 'http://it.archive.ubuntu.com/ubuntu focal-backports InRelease' changed its 'Origin' value from 'LP-PPA-zorinos-stable' to 'Ubuntu'
E: Repository 'http://it.archive.ubuntu.com/ubuntu focal-backports InRelease' changed its 'Label' value from 'Zorin OS Stable' to 'Ubuntu'
N: Repository 'http://it.archive.ubuntu.com/ubuntu focal-backports InRelease' changed its 'Suite' value from 'focal' to 'focal-backports'
E: Repository 'http://it.archive.ubuntu.com/ubuntu focal-backports InRelease' changed its default priority for apt_preferences(5) from 500 to 100.
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N]
Should I accept the changes?
Normally I would say "yes" or suggest to run
sudo apt --allow-releaseinfo-change update
But given that this changes a specific origin
from Zorin OS to Ubuntu...
I am not confident on this one.
Noting this for @staff so that hte ZorinGroup can glance this over in case it is risky.
So, how to update my system?
In the post above, I used the staff notification to alert the ZorinGroup.
Hey Aravisian,
if I now need to install a package that's not in ubuntu repos, I need to add the repo- and then run sudo apt update
. But with that command unavailable, how should I install this package? Should I fallback to Snap (aww man...)?
As a test, you might use Software & updates
and switch to
Download from: Main Server.
Then run sudo apt update
and relay the result of that here. Let's see if there is a difference between the main server and your regional server.
I have not gotten those label change messages that you have.
"Main Server" was already set, so I edited sources.list
The sudo apt update
command took some time, the mirrors were slow.
It worked but with some warnings. How can I solve them?
~/Pictures/Foto Pro Loco ▓▒░ sudo nano /etc/apt/sources.list ░▒▓ ✔ at 18:14:09
~/Pictures/Foto Pro Loco ▓▒░ sudo apt update ░▒▓ ✔ took 20s at 18:14:30
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Hit:3 http://repository.spotify.com stable InRelease
Get:4 http://packages.microsoft.com/repos/code stable InRelease [3.569 B]
Get:6 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Get:7 https://brave-browser-apt-release.s3.brave.com stable InRelease [7.547 B]
Get:8 https://dl.google.com/linux/chrome/deb stable InRelease [1.825 B]
Hit:9 https://repo.steampowered.com/steam stable InRelease
Hit:10 http://ppa.launchpad.net/zorinos/apps/ubuntu focal InRelease
Get:11 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Hit:12 http://ppa.launchpad.net/zorinos/drivers/ubuntu focal InRelease
Hit:13 http://ppa.launchpad.net/zorinos/patches/ubuntu focal InRelease
Hit:14 http://ppa.launchpad.net/zorinos/stable/ubuntu focal InRelease
Get:15 https://packages.zorinos.com/stable focal InRelease [9.406 B]
Get:16 http://packages.microsoft.com/repos/code stable/main armhf Packages [69,7 kB]
Get:17 https://packages.zorinos.com/patches focal InRelease [15,5 kB]
Get:18 http://packages.microsoft.com/repos/code stable/main arm64 Packages [69,4 kB]
Get:19 http://packages.microsoft.com/repos/code stable/main amd64 Packages [69,0 kB]
Get:20 https://packages.zorinos.com/apps focal InRelease [9.404 B]
Get:21 https://brave-browser-apt-release.s3.brave.com stable/main amd64 Packages [4.743 B]
Get:22 https://packages.zorinos.com/drivers focal InRelease [18,2 kB]
Get:23 https://dl.google.com/linux/chrome/deb stable/main amd64 Packages [1.065 B]
Get:24 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages [836 kB]
Get:25 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [2.610 kB]
Get:26 http://archive.ubuntu.com/ubuntu focal-updates/main Translation-en [439 kB]
Get:27 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 DEP-11 Metadata [274 kB]
Get:28 http://archive.ubuntu.com/ubuntu focal-updates/main DEP-11 48x48 Icons [60,8 kB]
Get:29 http://archive.ubuntu.com/ubuntu focal-updates/main DEP-11 64x64 Icons [98,3 kB]
Get:30 http://archive.ubuntu.com/ubuntu focal-updates/main DEP-11 64x64@2 Icons [29 B]
Get:31 http://archive.ubuntu.com/ubuntu focal-updates/main DEP-11 128x128 Icons [202 kB]
Get:32 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [16,8 kB]
Get:33 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [1.937 kB]
Get:34 http://security.ubuntu.com/ubuntu focal-security/main i386 Packages [602 kB]
Get:35 http://archive.ubuntu.com/ubuntu focal-updates/restricted i386 Packages [31,6 kB]
Get:36 http://archive.ubuntu.com/ubuntu focal-updates/restricted Translation-en [273 kB]
Get:37 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [636 B]
Get:38 http://archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages [730 kB]
Get:39 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [1.067 kB]
Get:40 http://archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [254 kB]
Get:41 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 DEP-11 Metadata [409 kB]
Get:42 http://archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 48x48 Icons [277 kB]
Get:43 http://archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 64x64 Icons [488 kB]
Get:44 http://archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 64x64@2 Icons [29 B]
Get:45 http://archive.ubuntu.com/ubuntu focal-updates/universe DEP-11 128x128 Icons [1.098 kB]
Get:46 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [24,9 kB]
Get:47 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [25,2 kB]
Get:48 http://archive.ubuntu.com/ubuntu focal-updates/multiverse i386 Packages [8.436 B]
Get:49 http://archive.ubuntu.com/ubuntu focal-updates/multiverse Translation-en [7.408 B]
Get:50 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 DEP-11 Metadata [944 B]
Get:51 http://archive.ubuntu.com/ubuntu focal-updates/multiverse DEP-11 48x48 Icons [1.867 B]
Get:52 http://archive.ubuntu.com/ubuntu focal-updates/multiverse DEP-11 64x64 Icons [2.497 B]
Get:53 http://archive.ubuntu.com/ubuntu focal-updates/multiverse DEP-11 64x64@2 Icons [29 B]
Get:54 http://archive.ubuntu.com/ubuntu focal-updates/multiverse DEP-11 128x128 Icons [29 B]
Get:55 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [612 B]
Get:56 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages [45,7 kB]
Get:57 http://archive.ubuntu.com/ubuntu focal-backports/main i386 Packages [36,1 kB]
Get:58 http://archive.ubuntu.com/ubuntu focal-backports/main Translation-en [16,3 kB]
Get:59 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 DEP-11 Metadata [7.988 B]
Get:60 http://archive.ubuntu.com/ubuntu focal-backports/main DEP-11 48x48 Icons [7.156 B]
Get:61 http://archive.ubuntu.com/ubuntu focal-backports/main DEP-11 64x64 Icons [10,7 kB]
Get:62 http://archive.ubuntu.com/ubuntu focal-backports/main DEP-11 64x64@2 Icons [29 B]
Get:63 http://archive.ubuntu.com/ubuntu focal-backports/main DEP-11 128x128 Icons [24,2 kB]
Get:64 http://archive.ubuntu.com/ubuntu focal-backports/main amd64 c-n-f Metadata [1.420 B]
Get:65 http://archive.ubuntu.com/ubuntu focal-backports/restricted amd64 c-n-f Metadata [116 B]
Get:66 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages [25,0 kB]
Get:67 http://archive.ubuntu.com/ubuntu focal-backports/universe i386 Packages [13,8 kB]
Get:68 http://archive.ubuntu.com/ubuntu focal-backports/universe Translation-en [16,3 kB]
Get:69 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 DEP-11 Metadata [30,5 kB]
Get:70 http://archive.ubuntu.com/ubuntu focal-backports/universe DEP-11 48x48 Icons [13,3 kB]
Get:71 http://archive.ubuntu.com/ubuntu focal-backports/universe DEP-11 64x64 Icons [22,7 kB]
Get:72 http://archive.ubuntu.com/ubuntu focal-backports/universe DEP-11 64x64@2 Icons [29 B]
Get:73 http://archive.ubuntu.com/ubuntu focal-backports/universe DEP-11 128x128 Icons [43,5 kB]
Get:74 http://archive.ubuntu.com/ubuntu focal-backports/universe amd64 c-n-f Metadata [880 B]
Get:75 http://archive.ubuntu.com/ubuntu focal-backports/multiverse amd64 c-n-f Metadata [116 B]
Get:76 http://security.ubuntu.com/ubuntu focal-security/main amd64 Packages [2.209 kB]
Get:77 http://security.ubuntu.com/ubuntu focal-security/main Translation-en [356 kB]
Get:78 http://security.ubuntu.com/ubuntu focal-security/main amd64 DEP-11 Metadata [59,9 kB]
Get:79 http://security.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [13,0 kB]
Get:80 http://security.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [1.802 kB]
Get:81 http://security.ubuntu.com/ubuntu focal-security/restricted Translation-en [253 kB]
Get:82 http://security.ubuntu.com/ubuntu focal-security/universe i386 Packages [600 kB]
Get:83 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages [842 kB]
Get:84 http://security.ubuntu.com/ubuntu focal-security/universe Translation-en [173 kB]
Get:85 http://security.ubuntu.com/ubuntu focal-security/universe amd64 DEP-11 Metadata [95,7 kB]
Get:86 http://security.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [18,4 kB]
Get:87 http://security.ubuntu.com/ubuntu focal-security/multiverse amd64 DEP-11 Metadata [940 B]
Fetched 19,1 MB in 55s (349 kB/s)
Reading package lists... Done
Building dependency tree
176 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Conflicting distribution: http://repository.spotify.com stable InRelease (expected stable but got focal)
W: Skipping acquire of configured file 'non-free/binary-amd64/Packages' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/binary-i386/Packages' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/i18n/Translation-en' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/i18n/Translation-en_US' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/dep11/Components-amd64.yml' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/dep11/icons-48x48.tar' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/dep11/icons-64x64.tar' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/dep11/icons-64x64@2.tar' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/dep11/icons-128x128.tar' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free/cnf/Commands-amd64' as repository 'http://repository.spotify.com stable InRelease' doesn't have the component 'non-free' (component misspelt in sources.list?)
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://brave-browser-apt-release.s3.brave.com stable InRelease' doesn't support architecture 'i386'
And then, how to report issue to italian mirror's holders?
Try this Spotify key:
wget -O- https://download.spotify.com/debian/pubkey.gpg | sudo apt-key add -
sudo add-apt-repository "deb http://repository.spotify.com stable non-free"
I have no idea on this, actually. The regional mirrors are supposed to be Synced and contain all the same stuff as the main server. But I have far too often see this to not be the case.
I mean:
Would need to identify who is maintaining the regional server you are using and find their contact info...
It may be GARR:
I know a guy that works there! What should I tell him?
SignorCastello:
Error 403: forbidden
pfuh... I just tested it and got the same. Why Spotify? Spotify is notorious about this.
That the server needs to be synced with main...
Ok, I'll do this as soon as I can.
Aravisian, I finally have updated completely my system. So, THANKS!!
(It took an hour cause I have a slow hdd...)
system
Closed
August 29, 2023, 6:28pm
18
