Hi!
I opened settings for jelly mode, tried to custom it a little bit but when i click on "Reset to default" I don't have the same settings as when I installed Zorin. I would like to know if it's possible to know what where default settings so I can set them.
Thx!
Click Zorin
icon bottom of screen, type EXTENSIONS
Scroll to find Jelly Mode. Should be a config button next to it.
And config you shall with great anticipation.
Good luck!
The thing is I know how to edit it, but I don't know what was Zorin default configuration, the values of the settings
When you hit reset to defaults, those defaults should be what Zorin OS was using previous to you getting touchy feely with the levers of memorizing jelly enchantment. lol
I also believed, but actually no
This is how mine looks like.
As I even did not know there was such control function, it is definitely set to default.
Thank's a lot man !
You are welcome, but you got my gender wrong ![]()
