Hi, I am new to my ZorinOS (Linux). I am very impressed with the operating system, but I still have a long way to go to get along with the platform properly.
I have a problem that I read about earlier in the forum, but I still can't get it installed on my laptop.
I would like to get Dukascopy's trading platform namely "JForex3 Linux" or "JForex4 Linux" 64-bit, installed on Zorin.
I have already tried everything, but no succes. I hope someone can show me the way.
Otherwise, I am very satisfied with my transition from Win10 to Zorin.
Best regards
M.
This One?
Yes indeed
I recommend JForex3 in order to avoid the numerous issues that can stem from using Java 17 on Linux.
As Aravisian says JForex3 is fine for me
Download the file and follow this tutorial.
Thanks for your link. Jforex3 Linux 64 bit finally works on my laptop with ZorinOS.
@MorananaroM , glad to hear that things worked out. Can you please select a post that notes the Solution that other users can use when searching this issue in future?
