Kernels 7.1.1, 7.1.2, 7.1.3
Should I be able to run these kernels with Zorin 18.1. After I install any of them from the mainline kernel and reboot it says I have to install then first.
Is secure boot disabled? Mainline kernels are not signed, so when secure boot is turned on they can not be loaded. Perhaps it helps to disable secure boot if you have enabled it. Be careful if you have an nvidia card and made the Zorin installation with secure boot enabled.
Can You make a Screenshot of the Message?
best way to get the kernel 7.0 series working is
follow instructions to use liquorix kernel i have it works awsome
it will over time merge into the newer kernels
If you need a later signed kernel, the 7.0 kernel may be an option:
I disabled secure boot. It works fine now. Thanks everyone.
