Hello again,
I'm running Zorin Core OS. I need to invert my FN key, so I can use the F keys for music and such, without pressing FN every time. I've tried FN+ESC, FN+NUM, FN+~ None of those seems to work. I'm using a Logitech G513 Keyboard Thanks
Thanks
Each keyboard has its own set of key combinations to control the "active layer" or functionality of the keys. You should read the user manual or contact for their support team.
Yeah, it says to download the logitech gaming software to invert the FN key.
I was able to figure it out with keyboard shortcuts
