Hi there,
probably it is very simple, but I cannot find the right key or shortcut. My touchpad is deactivated, I am able to use the keyboard to open the settings and navigate to the touchpad ("Mouse & Touchpad"). With TAB I can reach the setting (Touchpad/Touchpad) where the switch is set to OFF. Now the problem: which key do I have to use to switch it on again ??? Space and Enter does not work for me. Tried a lot more, but no luck.
Unfortunately I do not have a mouse to click on that field
With a mouse-click it works, I know.
No. Sounds good. I tried it now, I activated my touchpad (with a mouse-click) and tried it out. Works good. I will try this workaround which keeps touchpad always on.
Still would be curious if there is a solution to that switch Normally you would expect to switch is on/off with the space key when the option is selected.
Thank you very much
Helmuth
