my laptop's resolution is 720p(hd) i know my screen is not perfect for krita. krita does not properly fits in my screen and i face a lot of problem while using brush editor and time line in krita.
is there any way to fix it ??
krita verson - 5
krita verson - 5
You are not alone in this, even for Windows users.
Krita is written in QT, which can be used on Windows, too.
Have you tried scaling the image in order to change the Krita window resolution?
Image > Scale Image to New Size
yes, my high dpi support is already disabled.
sorry, it didn't helped me...
where is "scale image to new size option" ?
thank i got that. but its doing nothing
I would check in on the Krita help site as they would probably be far more experienced and knowledgeable, in this case.
okay, thanks in advanced
sir, its seems like you are very busy.
i got an idea. Is there any way to to decrease my global scaling less then 100% ?
i am not an expert but, may be that can fix it...
In general you could play around with the scaling of the screen. There are some tutorials how to scale below 100% (Gnome fractional scaling below 100%)
For Krita you could also try Settings β Configure Krita β General β Window β Enable Hdpi
Yes, i have also get this problem with KDEnlive. Thanks,but i don't get your solution. Please explain in a detailed way. ? .
But i am using. KDE plasma
Suggests ensuring it is the latest version of Krita and removing the file: ~/.kde/share/config/kritarc
Yes, now i am in the latest version of krita.
There is no file like kritarc . There is only file named as kdeglobals
You have KDE installed on Zorin OS, right?
I know that @swarfendor437 has experimented with that quite successfully. I have... a uhh... certain mindset... that disables my ability to properly enjoy... KDE...
LOL
But uhm... Maybe if Swarf is feeling cherry, he might be willing to take a look.
Sorry, i don't get it
Did you install the KDE Plasma Desktop on Zorin OS or are you using a Distro that comes with KDE?
I am on KDE neon. Because Installing KDE in Zorin is very buggy
Ok, can you try checking for kritarc in
~/kde/share/config/kritarc
or try
~/.config/kritarc
Another thing to check - if KDE Neon has the setting for window>workspace, try setting your workpspaces to default, then log out and in and test Krita resizing...
Yes, i got that, i have to delate that right ?
