[sudo] password for mech-1:
Settings for eth0:
Cannot get device settings: No such device
Cannot get wake-on-lan settings: No such device
Cannot get message level: No such device
Cannot get link status: No such device
No data available
I am on wifi only.
Bourne
August 21, 2021, 6:31pm
22
I don't have here any wifi just Ethernet Cable RJ 45 Cat7
Bourne
August 21, 2021, 6:35pm
23
I will try find some solution how to fix that. Today I am little tired. Thank you @Aravisian for your sacrifice time and try help.
Bourne
August 22, 2021, 11:28am
24
I wondering if my ethernet card using all or missing something to need best properly working?
What is output of:
ifconfig -a
Are you running Zorin in a virtual environment?
Bourne
August 22, 2021, 1:48pm
26
What you mean virtual box or something?
Yes, virtualbox or vmware?
Bourne
August 22, 2021, 1:51pm
28
Well when I Installed Zorin on external hard disk ssd then I suppouse this is not virtual. What is the sense installing good operative system on virtual box?
There are many good reasons to run in a virtual environment. Some are work related, some for testing...
But as that does not apply to you, let's move on:
What is your terminal output of:
ifconfig -a
Bourne
August 22, 2021, 2:10pm
30
billy@Zorin-16-Pro:~$ ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.80.118 netmask 255.255.255.0 broadcast 192.168.80.255
inet6 2a02:1660:6b07:ec00:403e:c47d:3d0a:79f5 prefixlen 64 scopeid 0x0
inet6 fe80::3ddb:8fe7:5a7e:56b7 prefixlen 64 scopeid 0x20
inet6 fdda:a3bc:fd75:0:4138:625:2e7f:31c8 prefixlen 64 scopeid 0x0
inet6 2a02:1660:6b07:ec00:8d41:94ca:edb:d931 prefixlen 64 scopeid 0x0
inet6 fdda:a3bc:fd75:0:19b5:e062:4a0e:c2bd prefixlen 64 scopeid 0x0
ether d8:cb:8a:70:06:f6 txqueuelen 1000 (Ethernet)
RX packets 2620 bytes 1736072 (1.7 MB)
RX errors 0 dropped 170 overruns 0 frame 0
TX packets 2220 bytes 468677 (468.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 19
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 497 bytes 48276 (48.2 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 497 bytes 48276 (48.2 KB)
Bourne:
device interrupt 19
It is normal. It is part of boot interrupt setting.
Your ethernet is not working at all? Or slow?
Bourne
August 22, 2021, 2:23pm
33
slow i think with fiber optic internet.
@Bourne I have no real idea what your problem is but I just did a websearch using:
"eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
and found this:
networking
I do not know if that helps or is irrelevant.
Bourne
August 29, 2021, 3:57pm
35
i checked with tooleth0 and now I see all correct settings.
Can this subject now be marked as Solved?
Is it something to do with that Cmos clear you performed in another thread?
[Usb] here no all device recognize correctly before I have usb unknown device. With simple Clear Cmos out battery and jbat1 clear cmos jumper. First used jumper next battery out. In two words "Reset Bios"
Bourne
September 5, 2021, 3:11pm
38
No. I remember i wasn't have installed a package tooleth0.
Let's see if this still working. I bet working
