no option for multiple language selection in zorin os 17. I cant add more than one language
In Settings > Region & Language > Manage languages - what do you see there? (A screenshot can help us to understand)
Is this a clickable button?
yes it is
What happens when you click it?
I've just gone into my VM and when I clicked on the top button it came back it had not installed completely, but this was only for English speaking countries hyphenation (Canada, US, Za (about 5 countries)) - no option for Bangladesh.
Then after install I get manage languages and this window appears:
Then if I select Install / Remove Languages:
Then if I check mark Bangla and look at languages it is greyed out, suspect I would need to select then apply-system wide:
And also check Regional settings:
Assuming that will change the whole system language to Bangla that I don't want. I use avro phonetic to convert English to Bangla was possible in previous version of zorin os
I have the same problem , no multiple language, still English or Arabic , one language no more.
You can change the input language source in keyboards section , not in Language settings
