I had noticed my fans were super quiet since i installed zorin, i ran my fingers over the cpu vent and it was too hot. I monitored the heat with psensor(i believe that was the application) and my temp was hitting 173 degrees! I did not hear my fans blowing at all. What do i do to ensure they turn on when necessary?
Have you checked BIOS?
yes my System Performance Mode is on " Intelligent Cooling"
Fahrenheit or celsius ?? If it is fahrenheit it would be around 73c
What model do you have ?
i was using psensor and i set it to show fahrenheit so it was 173 degrees, today it hit over 200. i have a lenovo ideapad 3 17iil05
