I’m a Windows 10 user, but was willing to try a new OS, so I picked Zorin OS because it looked pretty nice. (I had some issues installing it, but I think that’s related to the issue bellow)
I’m using a somewhat old hardware:
Gigabyte GA-970A-DS3P
AMD FX-6300
Corsair 4GB DDR3 667 x2
GTX750 1GB.
But for some reason, I can’t get it to make both USB work at same time.
I checked the BIOS, and there are some options about USB:
Enable Leacy USB, which is enabled.
Enable USB 3.0 Support, also enabled
XHCI Handoff/EHCI Handoff, workarounds for USB2/3
-XHCI enabled, EHCI disabled: USB 3.0 works, USB 2.0 don’t.
-XHCI disabled, EHCI enabled: USB 2.0 works, USB 3.0 don’t.
-Both enabled or both disabled: no USB works on Zorin.
I tried to reset the BIOS to Recommended Settings, but no success.
I tested the USB ports that wasn’t being recognized by Zorin OS with a MatisTek USB Doctor (a very USB multimeter), and there was energy even was able to charge my phone. Just not recognized by OS.
I’m sure all USB (on motherboard) are working properly because I have no issues on Windows 10. The problem is that this motherboard has two USB 3.0 only. (front panel was overused over 5 years and sometimes doesn’t work properly, so I unplugged it)
Any idea how to make it work properly on Zorin OS 15? (For now, I have no USB 3.0 port working on Zorin OS)
I will say right away that "anecdote does not equal evidence." In spite of this, I see a lot of questions about issues with Linux running Gigabyte MB's. I do not know if there truly is a correlation.
I think I added this to GRUB_CMDLINE_LINUX="iommu=soft", but I am sure I forgot to update grub.
But I'm still reinstalling everything because I was so furious nothing was working correctly I wiped my SSD to try again... lol (That's what three days trying to make it work does to you. lol)
Understandable.
I am notorious for wiping and reloading at the drop of a hat. I just reinstalled Zorin about two days ago, actually.
When you have it up and running, if still no USB 3.0, please review this thread:
By the way I found a silly bug. The info (where shows the hostname, ram, gpu and drive space) reports my 120GB SSD having 240GB space… lol (I’m pretty sure I didn’t my 240GB SSD isn’t connected… lol)
just remember to have your Partitions set to Ext2 - a non-journaling file-system. Ext3 and Ext4 are Linux journaling systems - unless of course you are a daredevil using BTRFS. Oh and you will need to set up TRIM - something that Windows does normally. If you have any precious data, use a mechanical drive - if you accidentally wipe a file from your SSD it is highly unlikely you could recover it.
