I have a Broadcom BCM4352 wifi adapter and when using the Live USB it is detected and works fine, but after install (Dual Boot, made a new partition on sda8) it doesn't activate.
When trying to enable it in the additional drivers menu I get an error about having no internet connection. When I try to install it via terminal after downloading the bcmwl source package I get dependency errors like dkms, linux-libc-dev and libc6-dev.
I guess I'll download some of those but I suspect there may be dependencies for those etc. So, considering I used the "download and include updates" option when installing or whatever, it seems like there may be an issue with the installer not including these packages like it should. Would anybody know of a way to force the (OS) install to work properly or conversely to install the needed dependencies from the Live USB into the installed OS?
P.S.
Also, I don't think this is related but in case it is I will add that there seems to be a bootloader issue where I can't see the grub menu but I can select Windows (down arrow + enter) or let Zorin boot. I did have lickgrub and puppy linux on the same drive and can't access that either. To boot the live USB I have to use advanced startup options in Windows 10. Before I installed I could just hit Esc at lick and get a grub minimal command line, type exit, and then I could select boot drives. I'm afraid to try to use the boot repair when it boots for now and I don't wanna fix what isn't broken ![]()
Thanks.
