Does anyone know if LibreOffice Draw as a typewriter function ... each quarter I send my doctor a copy of my blood work on a form I made for this purpose and it requires me to put the results in the little squares so she can trace my progress and then I can keep a copy and send her one too .... here is the form I made so you can see what I mean ....
For personal reasons it is not filled out but you can get the picture of what I want to do ... I was using Adobe Acrobat 9 to fill these numbers in using their typewriter mode .... but I can't find that anywhere in Libre Draw .... or maybe I'm using the wrong Libre program ....
OK I see what you are saying just redo the form in Calc instead of adding to my existing form .... may have to do that but I am not much good with spread sheets .... and it does look a bit more professional .... but I am going to have to learn how to do it .... more of life's little challenges .... LOL
Well, its not that as in professional. Its just easier for form cause its already a rows and column. A table one. And since forms like you post is like a table, it will be easier to create it in a table like software like spread sheets
You of course are right .... and I don't have to learn or use macro's because it is just plain adding in numbers .... which shouldn't be that hard .... LOL
Does Linux support Apache OpenOffice ???? ... I think I've tried it before on Doze ...
Thanks but I'm already trying to redo the form using Calc ... it does look a whole lot better .... so I'll work with that for a spell .... if it appears I'm overwhelmed I'll give Apache a try ...
Thanks a lot for your help and info ... now back to my Calc .... LOL
OK I'm finished and I am happy with the results .... I made a template just in case I mess something up (like I would ever do that LOL) ... here are the results ...
