Linux Assistant - Set it up but after checking, it says I need to set it up again
Linux Assistant did not show when looking at /var/lib/flatpak/exports/share/applications
So I'm pretty sure I don't have it installed anymore.
So, Linux Assistent is no longer in your apps list? That's good.
My advice: You're better off staying away from this app.
I agree.
I've been using Linux Assistant since the beginning as a DEB version without any problems. The Flatpak version isn't up to date, so I prefer to use the DEB version.
DEB version: 0.6.2
Flatpak version: 0.3.0
I think that is the problem, when I installed the flatpak (out of date version) it didn't work when installed.
I'll do without it.
