Liquorix kernel Merges into 7.3
So far the change log hasnt been posted as of yet..once it does I will post it here
Ther was no big Changelog. Only the Markers for the 7.3 Kernel Switch. No Details.
I have installed the Kernel, too but unfortunately I have an Issue with the Colors. They look washed out - as if a gray Haze would be over the Display. With the 7.2 Kernel or the 7.0 Zorin Kernel, I don't have that.
Odd... mines working fine......what kind of hardware you packing there @Ponce-De-Leon
heres a screen shot of my screen...looks awsome
Same here, no problem with my AMD GPU
The changelog from liquorix is really little like always but the changelog from 7.2.15 to 7.3.3 is really big ! 3 versions (7.3.1, 7.3.2, 7.3.3)
https://cdn.kernel.org/pub/linux/kernel/v7.x/ChangeLog-7.3.1
https://cdn.kernel.org/pub/linux/kernel/v7.x/ChangeLog-7.3.2
https://cdn.kernel.org/pub/linux/kernel/v7.x/ChangeLog-7.3.3
With a Screenshot, I can't capture it. I already tried it.
AMD APU Ryzen 3200G.
The 7.2 Kernel worked fine. I had the Thought that maybe the default Mesa Driver might be too old for the 7.3 Kernel. Maybe adding the kisak-mesa PPA and then installing a more current Version might help.
But is only a Theory. Maybe I will try it in the next Days. Or I wait for the next Liquorix Update and see how this behaves.
Thanks @Nourpon for posting the Changelog.....you da man..... :innocent:
