Live USB taking longer than 60 minutes to boot
I will add the comments in the description around installation. If an OS offers to create a separate admin (root) password I usually do this for an added layer of security. Just a reminder that this is a testing .iso from Artix Community, not an official release. I will look at that later. So when trying to update the VM it did not recognise the admin password so on second install attempt I chose to use the same password I assigned to my user. Then there was a keyring issue, so I used Arch Linux in search criteria to solve the issue. Got the updates done. Then started looking for additional apps. Nothing. Now bear two things in mind.
  1. This is a testing iso and a Community release not official.
  2. It was only released this month.
The video is still uploading, then Vimeo has to do it's magic before it is finally available, but it will be here:
It is now viewable, but annoyingly only max is 720p - used same settings as a previous video so not sure what is gong on - plus, title clip I added is not showing!
They have just done their magic and now can be viewed in 1080p - forget it takes time for them to do this!
Well annoyingly SimpleScreenRecorder does not appear to have picked up the audio of the VM which worked perfectly in respect of sound working in the VM.
Well found out what the sound issue was. Needed PulseAudio if using simplescreenrecorder in Zorin. On Q4OS I have always used ALSA!
Just got round to install main Plasma stable .iso with s6 init in virt-manager. It comes with kernel 6.13 but updates to 6.15 post install. Found this useful guide for anyone wanting to play with Artix:
https://www.linux.org/threads/things-to-do-after-installing-artix-linux.39252/#post-152433
Awesome! Thank you!
