Locales in deprecated pam_environment module
It took me quite a while to find out where my locale settings where stored (LC_*).
Turned out that the Zorin Settings are using $HOME/.pam_environment to that end.
Now the PAM environment module is deprecated for a very long time (for security and convenience) reasons so I'm wondering why Zorin is still using it and if there are better options.
I can manually delete the file but if I change something 1 year from now I'll definitely look in the settings and run into it again.
I have moved this from "Customisation" to "General Help", as it does not fit in Customisation.
@Herman are you asking for help, or simply providing feedback re pam_envionment ?
If the latter, we may move again to the "Feedback" section where it may get noticed by the devs.
I'm asking for help. Can I configure Zorin in such a way that it gets rid of the PAM environment module.
The rest is the reasoning why I ask.
ZorinOS 17 is based on Ubuntu 22.04. You may find more by doing a websearch using e.g. "locale settings without pam.environment Ubuntu 22.04"
I have just done that and there were many hits, so would take time to find information that suits you.
example: environment variables - What should I use in instead of ~/.pam_environment (deprecated)? - Ask Ubuntu
That is all nice and clear but the issue is with the Settings application in the desktop.
I can configure my system from the terminal, deleting the pam environment, ... been there, done that but as soon as I touch the "Language & Region" settings in the desktop the pam thing is back and it screws up all the rest.
I thought the sole purpose of Zorin is to have a consistently working desktop environment.
