LocalSend not working in Zorin OS 18.1 Pro
Hello
I installed LocalSend app from the software manager. It shows the icon, but When I click on it, nothing shows up. But the program seems to run in the backround.
Can someone help?
Best regards,
Asto
You can try to clear the fontconfig cache
rm -rf ~/.cache/fontconfig
fc-cache -fv
Then logout and login again and try to launch the app.
If it doesn't help and you have installed the flatpak, you could try it with the .deb package.
This worked like magic. LocalSend works now. Was it because I upgraded from Zorin OS 18.1 Core?
No, this is a known Ubuntu Issue.
