Do You have this Problem after a Reboot? If You not tested that and it is a good Timing I would suggest to turn off Your PC and start him and look if it is still there.
The next Thing are the Gnome Extensions. Do you still have installed some Extensions that are used for the Activities Icon or the Top Bar?
