I just download Zorin Like Yesterday Really Loving It But I Cant set a different wallpaper for my lockscreen I wonder why do I need a pro version to set wallpaper on lock screen or something else
On Lite, a user can easily set the login wallpaper.
sudo apt install lightdm-gtk-greeter-settings
Launch the LightDm Greeter Settings app from the app menu.
In the Appearance tab under Background, set the desired wallpaper for the Loginscreen.
          I have the core version
You can refer to 337harvey's post above, doing so I came across
You can try the suggestions(The extension is mentioned a bit further down)
