I installed Zorin OS 17 Pro and unfortunately my logitech touchpad is not working. I tried to disable and enable the touchpad in the settings. As it is connected via bluetooth I also tried to plug it and use it but it still does not work. The touchpad in my laptop works, just the external touchpad does not.
Try install the touchpad drivers.
sudo apt install xorg-driver-input-synaptics
Please plug in to USB, open a terminal and enter the command:
lsusb
and post back the results please.
Looks like it works on some devices and distributions but not all:
I could not see any reference to touchpad in lsusb and made the assumption the touchpad is not the fingerprint reader.
Thank you for your reply. But I'm kinda new to Linux, would you mind telling me how I am to install the link you sent? Thank you!
The link is just a table showing which computer hardware and which Linux Distributions work with that device.
