i click cancle it open riot client and i press play it show league of legends and than deyssapers and nothing happend smo help?
The AntiCheat software some games use notoriously block Linux entirely.
So i need to turn on anti cheat?
Maybe on Show Details we could read something interesting, I tried with an .exe and I saw 2 sus modules listed as Dwarf and 1 as Export while all others were listed as Deferred
, but I'm not enough expert to understand all this stuff ![]()
Unhandled exception: page fault on read access to 0x00000018 in 32-bit code (0x0057b84b).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:006b GS:0063
EIP:0057b84b ESP:008ef8ec EBP:008ef900 EFLAGS:00010212( R- -- I -A- - )
EAX:008ef914 EBX:0000000f ECX:00000000 EDX:00000000
ESI:02899740 EDI:00000000
Stack dump:
0x008ef8ec: 008ef920 00632994 02899740 02899740
0x008ef8fc: 0000000f 008ef92c 005755e6 0000000f
0x008ef90c: 0289000f 00000000 0289000f 00000000
0x008ef91c: 008ef920 0289000f 00632994 02899740
0x008ef92c: 008ef938 0057cf90 008efa0c 008ef974
0x008ef93c: 0057cc1c 0000000f 00000000 00000000
Backtrace:
=>0 0x0057b84b ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=(nil), _message={mError={mError=0x23}, mQualifier={mQualifier=0x10212}}, _rethrow=false, _retry=true, collective=true, temp={="????"}, path={=""}, volume={=""}, textureName={=""}, myStream=0x8ef8ec, columns=0xffff, rows=0x1fa0, k=0x10212, j=0x23, i=0x57b84b) in lego bionicle (0x008ef900)
1 0x005755e6 ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=(nil), _message={mError={mError=0xffff}, mQualifier={mQualifier=0x9ac90000}}, _rethrow=false, _retry=false, collective=true, temp={="?????????????"}, path={=""}, volume={=""}, textureName={="?"}, myStream=0x860dab8f, columns=0xc00b, rows=0xea580000, k=0x9ac90000, j=0xffff, i=0x1fa0) in lego bionicle (0x008ef92c)
2 0x0057cf90 ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=0xc00b, _message={mError={mError=0xbffd}, mQualifier={mQualifier=0}}, _rethrow=false, _retry=false, collective=false, temp={="???????"}, path={="????"}, volume={=""}, textureName={=""}, myStream=(nil), columns=0x80000000, rows=0, k=0, j=0xbffd, i=0x860dab8f) in lego bionicle (0x008ef938)
3 0x0057cc1c ScTileFont::ScTileFont+0xffffffff(this=0xc003, mslException=0xc003, message=0xa0000000, _message={mError={mError=0xa8000000}, mQualifier={mQualifier=0xc005}}, _rethrow=true, _retry=false, collective=false, temp={=""}, path={="??????????????????"}, volume={=""}, textureName={=""}, myStream=(nil), columns=0, rows=0, k=0xc005, j=0xa8000000, i=0) in lego bionicle (0x008ef974)
4 0x0057cb27 ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=(nil), _message={mError={mError=0x43000000}, mQualifier={mQualifier=0}}, _rethrow=false, _retry=false, collective=false, temp={=""}, path={="??"}, volume={="????????????"}, textureName={=""}, myStream=(nil), columns=0, rows=0, k=0, j=0x43000000, i=0) in lego bionicle (0x008efa20)
5 0x00584474 ScSLOSIAnalogControllerAction::Fire+0xf3(inTrigger=0x29da4c0) [C:\Projects\lego\Sage\NorthWorks\script\osi\extensions\SfOSIExtAnalogControllerAction.cpp:18] in lego bionicle (0x008efabc)
6 0x00478791 ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=0x200, _message={mError={mError=0}, mQualifier={mQualifier=0}}, _rethrow=true, _retry=true, collective=false, temp={=""}, path={=""}, volume={="??"}, textureName={=""}, myStream=(nil), columns=0, rows=0, k=0, j=0, i=0) in lego bionicle (0x008efad0)
7 0x00490a8f ScTileFont::ScTileFont+0xffffffff(this=0x8, mslException=0x2899740, message=0x632994, _message={mError={mError=0}, mQualifier={mQualifier=0}}, _rethrow=false, _retry=false, collective=false, temp={=""}, path={=""}, volume={="$"}, textureName={="??"}, myStream=(nil), columns=0, rows=0x8ef450, k=0, j=0, i=0x200) in lego bionicle (0x008efaf4)
8 0x00490a39 ScTileFont::ScTileFont+0xffffffff(this=0x7bc26791, mslException=(nil), message=(nil), _message={mError={mError=0}, mQualifier={mQualifier=0}}, _rethrow=false, _retry=true, collective=true, temp={=""}, path={="#"}, volume={="??$"}, textureName={="??????"}, myStream=0x8ef44c, columns=0x8ef4b4, rows=0x8, k=0xf7d225c5, j=0, i=0) in lego bionicle (0x008efb0c)
9 0x0049253b ScTileFont::ScTileFont+0xffffffff(this=0x8, mslException=(nil), message=(nil), _message={mError={mError=0}, mQualifier={mQualifier=0x57b84b}}, _rethrow=true, _retry=true, collective=false, temp={=""}, path={=""}, volume={=""}, textureName={="??????????"}, myStream=0x8ef4b4, columns=0xf7d2df0e, rows=0x8ef480, k=0x8, j=0x7bc26791, i=0x8ef468) in lego bionicle (0x008efb30)
10 0x00491559 ScTileFont::ScTileFont+0xffffffff(this=0xf7d2ea1c, mslException=0x289000f, message=0xf, _message={mError={mError=0x577059}, mQualifier={mQualifier=0x8ef920}}, _rethrow=true, _retry=true, collective=true, temp={=""}, path={=""}, volume={="3???"}, textureName={="??????????????????????????"}, myStream=0xa, columns=0x8eff8c, rows=0x8ef5b0, k=0x1, j=0xf7f87539, i=0x8ef4d4) in lego bionicle (0x008efb7c)
11 0x0043e443 ScTileFont::ScTileFont+0xffffffff(this=0x8ef5b0, mslException=0x8ef920, message=(nil), _message={mError={mError=0x2899740}, mQualifier={mQualifier=0xf}}, _rethrow=true, _retry=false, collective=false, temp={=""}, path={=""}, volume={=""}, textureName={="??????????????????"}, myStream=(nil), columns=0x8ef894, rows=0x8ef5b0, k=0x8ef5b0, j=0x8ef894, i=0x64) in lego bionicle (0x008efb8c)
12 0x00483911 ScTileFont::ScTileFont+0xffffffff(this=0x8ef894, mslException=(nil), message=0x8e000f, _message={mError={mError=0xf}, mQualifier={mQualifier=0}}, _rethrow=true, _retry=true, collective=true, temp={="???W???c????"}, path={=""}, volume={=""}, textureName={=""}, myStream=0x7bc581bd, columns=0x1003f, rows=0x8ef5b0, k=0x8ef900, j=0, i=0x2899740) in lego bionicle (0x008efc78)
13 0x004d0f7b ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=0x8efa74, message=0x8efa6c, _message={mError={mError=0x29da4c0}, mQualifier={mQualifier=0x291bbc0}}, _rethrow=false, _retry=false, collective=false, temp={="?"}, path={=""}, volume={=""}, textureName={="?"}, myStream=(nil), columns=0, rows=0x23, k=0, j=0, i=0x1003f) in lego bionicle (0x008efca8)
14 0x004d0e91 ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=0x4836d0, message=0x4836b0, _message={mError={mError=0x40b98739}, mQualifier={mQualifier=0x1004e}}, _rethrow=false, _retry=false, collective=false, temp={="?G???c"}, path={=""}, volume={=""}, textureName={=""}, myStream=(nil), columns=0x43000000, rows=0, k=0, j=0, i=0) in lego bionicle (0x008efe54)
15 0x0040107b ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=(nil), message=0x1, _message={mError={mError=0x25b1160}, mQualifier={mQualifier=0x8efd28}}, _rethrow=false, _retry=false, collective=false, temp={="????"}, path={="Ø??????????X?`?????????????????????????
"}, volume={="?W"}, textureName={=""}, myStream=(nil), columns=0, rows=0, k=0, j=0, i=0) in lego bionicle (0x008efeb0)
16 0x0058a21c OSIScSLOSIFileIOLoadOSIObject+0x554b(@temp_ptr@=0x8eff48, vm=0x7b62e270, argVal1=0x3fe000) in lego bionicle (0x008eff28)
17 0x0040100d ScTileFont::ScTileFont+0xffffffff(this=(nil), mslException=0x8efd0c, message=0x260ade0, _message={mError={mError=0xf0}, mQualifier={mQualifier=0x6164b4}}, _rethrow=true, _retry=true, collective=false, temp={=""}, path={=""}, volume={="????????????????????????"}, textureName={=""}, myStream=(nil), columns=0, rows=0, k=0, j=0, i=0) in lego bionicle (0x008eff30)
18 0x7b62e270 EntryPoint+0xffffffff() in kernel32 (0x008eff48)
19 0x7bc5bc77 EntryPoint+0xffffffff() in ntdll (0x008eff5c)
20 0x7bc5bed0 EntryPoint+0xffffffff() in ntdll (0x008effec)
0x0057b84b ScTileFont::ScTileFont+0xffffffff in lego bionicle: movl 0x18(%edi),%esi
Modules:
Module Address Debug info Name (48 modules)
PE 400000- 6da000 Export lego bionicle
PE 8f0000- a61000 Deferred winmm
PE a70000- ef6000 Deferred ole32
PE f00000- 13ab000 Deferred comctl32
PE 13b0000- 163f000 Deferred comdlg32
PE 1640000- 1739000 Deferred d3d8
PE f120000- f4d6000 Deferred quartz
PE 10000000-10084000 Deferred d3dx8cw
PE 30000000-30059000 Deferred binkw32
PE 60000000-6005d000 Deferred ijl15
PE 61740000-61828000 Deferred advapi32
PE 62fc0000-631f2000 Deferred rpcrt4
PE 63480000-6349c000 Deferred version
PE 63bc0000-63c02000 Deferred shcore
PE 64a40000-64b5e000 Deferred shlwapi
PE 64ec0000-652ab000 Deferred oleaut32
PE 65bc0000-65bda000 Deferred midimap
PE 67a00000-67a83000 Deferred d3dxof
PE 67d40000-67dc4000 Deferred mmdevapi
PE 682c0000-6844c000 Deferred dsound
PE 68500000-6864b000 Deferred combase
PE 68700000-6878e000 Deferred uxtheme
PE 6a040000-6a0a3000 Deferred msacm32
PE 6a280000-6a4c9000 Deferred msvcrt
PE 6bb00000-6bb6b000 Deferred msvfw32
PE 6bc00000-6bca2000 Deferred sechost
PE 6bcc0000-6be9c000 Deferred setupapi
PE 6c0c0000-6c10d000 Deferred msdmo
PE 6c9c0000-6cf3f000 Deferred gdi32
PE 6ec00000-6eca2000 Deferred devenum
PE 6ed00000-6f392000 Deferred user32
PE 70040000-70063000 Deferred msacm32
PE 70b40000-70df7000 Deferred ucrtbase
PE 71200000-71248000 Deferred imm32
PE 71440000-7153d000 Deferred avifil32
PE 7a820000-7a824000 Deferred opengl32
PE 7b000000-7b30b000 Deferred kernelbase
PE 7b600000-7b928000 Dwarf kernel32
PE 7bc00000-7bee0000 Dwarf ntdll
PE 7bf30000-7bf34000 Deferred winegstreamer
PE 7c420000-7c423000 Deferred winealsa
PE 7d020000-7d023000 Deferred avicap32
PE 7d670000-7d673000 Deferred winepulse
PE 7e790000-7e794000 Deferred winex11
PE 7ed70000-7ed74000 Deferred wined3d
PE 7ef00000-7f7d7000 Deferred shell32
PE 7f8f0000-7f8fb000 Deferred winspool
PE 7f940000-7f94b000 Deferred dinput8
Threads:
process tid prio (all id:s are in hex)
00000038 services.exe
0000003c 0
00000040 0
0000004c 0
0000005c 0
00000074 0
0000008c 0
00000098 0
000000b8 0
000000d8 0
00000044 winedevice.exe
00000048 0
00000054 0
00000058 0
00000060 0
00000064 plugplay.exe
00000068 0
00000078 0
0000007c 0
00000080 0
000000a0 0
00000084 winedevice.exe
00000088 0
00000090 0
00000094 0
0000009c 0
000000ac 0
000000b0 svchost.exe
000000b4 0
000000bc 0
000000c0 0
000000d0 rpcss.exe
000000d4 0
000000e0 0
000000e4 0
000000e8 0
000000ec 0
00000110 0
000000f8 (D) C:\Giochi\LEGO Bionicle\LEGO Bionicle.exe
000000fc 0 <==
00000114 0
00000118 0
0000011c 15
00000120 0
00000124 15
00000128 0
00000134 0
00000138 0
0000013c 0
00000174 0
00000178 0
0000017c 0
0000018c 0
00000100 explorer.exe
00000104 0
00000108 0
0000010c 0
System information:
Wine build: wine-6.0.3 (Ubuntu 6.0.3~repack-1+zorin1)
Platform: i386 (WOW64)
Version: Windows 10
Host system: Linux
Host version: 5.15.0-73-generic
Do you know how i can fix that?
I don't, sorry, for now I'm not using Wine or running .exes, I stopped after seeing many errors like yours and the difficulty on resolving them. I'm not enough good to do it in short times so I preferred not to go on.
