A long-good SMB connection is now failing.
The link smb://pcname.local/sharename was working for the longest time to connect me to a drive on a Windows machine.
Fine. I removed and re-added the connection in Zorin's "Files" making sure to use the correct user ID, workgroup, and password.
I know they are correct since after re-adding the connection and still seeing a failure I reset that info on the host PC!
I am getting the error:
Failed to mount Windows share: INVALID ARGUMENT
If I use the format smb://pcname.local/sharename I do not get asked to log in, there are just a few moments before it fails to that error.
If I use the format smb://pcname/sharename I DO get asked to log in, then it fails.
Connections to the same host/share are working for the Windows PCs on the network.
Thanks all.
Zorin OS 16.3
