Is there an Orchis Dark theme available for Emerald, or are there any beautiful themes, as the themes I have seen are not attractive at all and the corners are not rounded?
There is a green Version of Orchis Dark.
What do you mean by a green version of Orchis Dark? Do you mean that Compiz supports Orchis Dark Green? I tried to use it, but it doesn't support it.
When I use Compiz and apply any theme that supports rounded corners, like Orchis Dark, it appears like this
But when I enable the default XFCE window manager, it appears normally. The issue is therefore with Compiz.
When You look at Your Picture, you see that the Corners are rounded but behind is a darker black Placeholder.
Look there in the File List and You see:
Alternatively, You could download it from the Github Page and use the Install Script for installing the Color You want and set up a custom Value for the rounded Corners:
