Hi Everyone!
First of all, kudos to the whole team and community on Zorin OS. It's fantastic
I purchased Zorin Ultimate a year back, and have had a great experience so far. Was more than excited to try out Zorin OS 16 Beta Release. Here is the only issue I'm facing:
- Open Terminal Window (let's call it X)
- Switch to any other window (or even a different terminal) (let's call it Y)
- The font color lightens on Window X (see screenshot below)
With focus, this is how it looks:
Is it intentional?
My very first question is, is it intentional? The reason this doesn't look the best to me, is in case I'm streaming or sharing my screen and I lose the focus from my Terminal, I don't like the font color lightening.
While this is a personal opinion, I understand it can be something the majority of the community likes - and I totally understand. But I'll appreciate it if I can disable this effect - any help on this is highly appreciated.
Thanks!
I am reasonably sure that it is intentional, since having a window change appearance when not in focus allows the user to easily differentiate between active windows. It is something I make use of a lot, myself.
There are many ways to go about it- for me, I change the Window Borders more often than the Text. But yes, you can take full control of this.
Please navigate to your home config directory
~/.config/gtk-3.0
and create a new document named gtk.css and save it.
In the open document paste in the following:
terminal-window .terminal-screen { background-color: #F5F7FA;
color: #022547;
terminal-window .terminal-screen:backdrop { background-color: #F5F7FA;
color: #022547;
Change the colors to suit however you want. The above hexadecimal color codes are a guess on my part, based on the screenshot you shared.
Save the document and log out and in to see the effect. (Or, you can press alt+F2 and enter in the letter r for restart and hit enter to restart the shell).
From this gtk.css document in the ~/.config/gtk-3.0 directory, you can modify other portions of the theme that you may wish to tweak, so feel free to feel the power and to ask any questions.
Hi, @Aravisian - Thanks a lot for your quick response. I really appreciate that.
I did try this, doesn't look like it changed anything (after trying to restart the shell). I'll try the log-out in a few hours (can't do it now, sorry - a build is running).
I'll get back here in case it doesn't work or if it works. It's interesting that it's intentional, I might take some time to get used to it and who knows? Maybe I'll start liking it as well
Thank you again for your response and great work.
Yes, I may be wrong about restarting the shell. That would affect only the Gnome-Shell portions (governed by gnome-shell.css). Sorry- I do not use gnome, so I forget some things about how it works once in a while.
I am quite sure that logging out and in again will demonstrate the change. BUT - if you prefer to not log out and in - open Zorin Appearance and change your theme to a different one. Then change it back to the one you are using now - and that should show the changes.
Thanks for the response, again. @Aravisian
Please don't apologize, that's fine. Just curious though, what do you use then? I had made a safe assumption that everyone here uses Zorin
So I thought I'll try and log out because opening Zorin Appearance and changing the theme, unfortunately, didn't work.
Logging out did solve the problem though. Thank you very much!
I use Zorin OS, but not Gnome Desktop.
Zorin OS comes in Core Gnome Desktop Environment or Zorin OS Lite XFCE4Desktop Environment. Zorin Ultimate offers a choice of Gnome or XFCE4.
I prefer XFCE4 or Cinnamon Desktop (the Linux Mint Desktop). I am currently using Zorin OS 16 Beta- I installed the XFCE4 desktop environment on it (And I installed Cinnamon Desktop on it).
Oh wow! Sorry, I forgot - you can install different desktop environments after all. That's great.
I'll try out something like this as well maybe.
Thanks!
