Low battery power pop up
Can someone within Zorin and/or Ubuntu please fix the annoying 'low battery' pop up ? I get it every time I start my PC. It is not just annoying actually. It is frustrating there is no solution. A simple on/off switch would help.
I have looked for a solution. Nothing.
if you open settings then move to notifications is there a power section with a switch there?
There is no setting where you can disable only that notification for low battery.
Perhaps it could help to edit the file
/etc/UPower/UPower.conf
and change the value for PercentageLow=20 to a lower value and then to run sudo systemctl restart upower and reboot the system.
You need root rights to do this and you'll see a message in the file that only the system vendor should change that file.
I haven't tested it myself. If you have a laptop it is not a good idea to set the value too low.
If the laptop is plugged into the wall, the charge adapter should not let the battery dip that low, it should charge it up. If the user is running off the battery all the time, that explains it. Hopefully your charge adapter works. I am so tired of laptops, I am so glad I switched to a higher powered, less stifled, desktop.
