ah update on this. Soon after making the above change I started to experience a lot of display issues, freezing windows etc. I uninstalled Brave and the issue resolved. clearly a problem with Wayland and Brave..
-chuckle- no problem. I have removed the Solution mark.
I agree: What is the difference between a "solution" and a "workaround"? There is no truly defined difference and the usage varies based on how happy the user is to get the problem to go away.
Many posters do not actually mark the solution on solved threads, so I have gotten used to tagging along and marking them. A marked solution helps other users find means of addressing problems.
You do have the ability to mark (and to change the mark of) solutions in your thread, so I will trust that to you.
