What concerns me is that from an accessibility point of view.
I did a search about compatibility of the font with WebkitGTK 4.1 using Brave search engine via Mojeek and Brave's A.I.
My search criteria:
Will opendyslexic font ever work with webkitgtk 4.1?
"Based on my research, there is no known fundamental incompatibility between OpenDyslexic and WebKitGTK 4.1. OpenDyslexic is a standard OTF/WOFF2 font that integrates through fontconfig, which is how WebKitGTK 4.1 discovers system fonts. If it's not rendering for you, the likely culprits are:
Fontconfig cache issues — run fc-cache -fv and verify with fc-list | grep -i opendyslexic .
Font-weight offset — WebKitGTK adds ~100 to font-weight on Linux, making text render bolder than expected. Compensate by requesting a lighter weight.
Font scanning hangs — with large font collections, WebKitGTK can spin at 100% CPU during font enumeration before the first page commit. A restricted fontconfig can work around this.
Sandboxed environments — if the app uses bubblewrap (e.g. Flatpak), user-installed fonts in ~/.local/share/fonts may not be visible inside the sandbox.
There's no open WebKit bug specifically about OpenDyslexic failing to load. If you're seeing a specific symptom (blank window, wrong font, missing glyphs), that context would help narrow it down further."
I then looked at the Flatpak sandbox option:
How to install OpenDyslexic in Flatpak sandbox?
Researched OpenDyslexic Flatpak installation
The good news is that Flatpak already exposes ~/.local/share/fonts to the sandbox at /run/host/user-fonts by default (since Flatpak 1.8.0), so no extra permissions are needed in most cases.
Steps:
- Install the font to the user font directory:
mkdir -p ~/.local/share/fonts
# Copy the .ttf/.otf files there, or use your distro's package manager:
# sudo apt install fonts-opendyslexic (Ubuntu/Debian)
# sudo dnf install opendyslexic-fonts (Fedora)
System-wide installs to /usr/share/fonts also work — Flatpak mounts those at /run/host/fonts .
- Refresh the fontconfig cache on the host:
fc-cache -fv
- Restart the Flatpak app.
If it still doesn't appear (e.g., you have custom fontconfig rules, or an older Flatpak):
# Grant read access to your user font dir (usually unnecessary on modern Flatpak):
flatpak override --user --filesystem=~/.local/share/fonts:ro
# If you rely on custom fontconfig config:
flatpak override --user --filesystem=xdg-config/fontconfig:ro
You can verify the font is visible inside the sandbox with:
flatpak run --command=fc-list <app-id> | grep -i opendyslexic
Common gotcha: Flatpak does not expose host fontconfig config files by default. If you have a custom ~/.config/fontconfig/fonts.conf with aliases or substitutions, you'll need the xdg-config/fontconfig:ro override above for it to apply inside the sandbox."
So I am looking at it from a different angle. ZorrinOS 17 was the first GNU/Linux distro (TTBOMK) to include two open source accessible fonts, ComicRelief, an alternative to the proprietary MSComicSans, and Opendyslexic.
@AZorin and @zorink does the fact that this major issue, specifically related to WebkitGtk4.1 and Opendyslexic font effectively prevent Dyslexic users from being able to use ZorinOS?
I am also wondering if this issue might have been why other distributions remained on WebkitGTK4.0.
So looking at the initial response of the search, font-config appears to be the culprit - so what is this a part of? The Linux kernel? (Bearing in mind Ubuntu uses a modified kernel).
