Lutris/Wine reset
Hi everyone,
I'm running into some issues using Lutris, and I'd like resetting everything up to the initial config. Is there a proper way to uninstall them both and then reinstalling them?
I was facing a general error while trying to install League of Legends:
Exit with return code 256
I was reading that this could be anything, so it was preferable to reinstall everything.
I've tried with:
sudo rm -rf /var/lib/lutris
sudo rm -rf /var/lutris
sudo rm -rf /lutris
rm -rf ~/.config/lutris
sudo rm -rf /var/lib/wine
sudo rm -rf /var/wine
sudo rm -rf /wine
rm -rf ~/.config/wine
rm -rf ~/.wine
rm -rf ~/.lutris
sudo apt purge wine
sudo apt purge winetricks
sudo apt purge lutris
sudo apt autoremove
sudo apt install wine
sudo apt install winetricks
sudo apt install lutris
winecfg
This however has installed wine 6 (I previously had wine 8) and now I'm not even able to install the Epic Games launcher.
Additional info: I cannot even run games on Steam, they just hang on starting up.
Editing to add some context:
I have firstly noticed that this was the error:
Start monitoring process.
00bc:err:esync:esync_init Failed to open esync shared memory file; make sure no stale wineserver instances are running without WINEESYNC.
Monitored process exited.
Initial process has exited (return code: 256)
So I did disable ESYNC on Wine runner (via Lutris, after the whole reinstallation).
Then I had this error:
00c0:err:environ:run_wineboot boot event wait timed out
wine: could not load kernel32.dll, status c0000135
So I have removed .wine/ and I'm now getting:
warning: Your version of wine  is no longer supported upstream. You should upgrade to 7.x
grep: /home/bl4ckk/Games/epic-games-store/*.reg: File o directory non esistente
WINEPREFIX INFO:
Drive C: totale 12
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 21:35 .
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 21:35 ..
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 21:35 users
Registry info:
warning: /home/bl4ckk/.local/share/lutris/runners/wine/wine-ge-8-17-x86_64/bin/wine cmd.exe /c echo '%AppData%' returned empty string, error message "/home/bl4ckk/.local/share/lutris/runners/wine/wine-ge-8-17-x86_64/bin/wine: /lib/i386-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by /home/bl4ckk/.local/share/lutris/runners/wine/wine-ge-8-17-x86_64/bin/wine)"
All processes have quit
DEBUG    2023-10-11 21:44:13,309 [command.on_stop:195]:Process 65210 has terminated with code 256
DEBUG    2023-10-11 21:44:13,808 [commands._monitor_task:449]:Return code: 256
ERROR    2023-10-11 21:44:13,809 [errors.__init__:18]:Command exited with code 256
And I'm still there.
Hi, this:
ll ~ | grep .wine|.lutris
is resulting in:
.lutris: comando non trovato (command not found)
While:
ll ~/.config | grep wine|lutris
is just opening Lutris.
How should I proceed?
It might sound strange, but even ls is opening Lutris for some reason....
Just to be sure I've checked for ll alias and it seems to be pretty standard
alias ll='ls -alF'
It might be something with the pipe itself. By just greping wine or lutris it's performing a normal search.... weird thing
Ooooh I got the point, it was piping into lutris command. Heh!
I will try with wine 8 and will let you know
No luck, I think..
2023-10-11 22:46:10,692: Creating a win64 prefix in /home/bl4ckk/Games/epic-games-store
2023-10-11 22:46:41,238: Wine prefix creation is taking longer than expected...
Still stuck
It seems the directory where Wine is trying to add the prefix (WINEARCH=win64 WINEPREFIX=/home/bl4ckk/Games/epic-games-store) is getting deleted.
I tried creating it manually before running the installer, but it gets deleted as soon as I press the install button. Then it stays stuck.
After a long while:
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEDEBUG=""
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEARCH="win64"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINE="/home/bl4ckk/.local/share/lutris/runners/wine/wine-ge-8-17-x86_64/bin/wine"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINE_MONO_CACHE_DIR="/home/bl4ckk/.local/share/lutris/runners/wine/lutris-ge-lol-p8-12-x86_64/mono"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINE_GECKO_CACHE_DIR="/home/bl4ckk/.local/share/lutris/runners/wine/lutris-ge-lol-p8-12-x86_64/gecko"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:GST_PLUGIN_SYSTEM_PATH_1_0="/home/bl4ckk/.local/share/lutris/runners/wine/lutris-ge-lol-p8-12-x86_64/lib64/gstreamer-1.0/:/home/bl4ckk/.local/share/lutris/runners/wine/lutris-ge-lol-p8-12-x86_64/lib/gstreamer-1.0/"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEPREFIX="/home/bl4ckk/Games/epic-games-store"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEESYNC="0"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEFSYNC="1"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINE_FULLSCREEN_FSR="1"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:DXVK_NVAPIHACK="0"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:DXVK_ENABLE_NVAPI="1"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:PROTON_BATTLEYE_RUNTIME="/home/bl4ckk/.local/share/lutris/runtime/battleye_runtime"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:PROTON_EAC_RUNTIME="/home/bl4ckk/.local/share/lutris/runtime/eac_runtime"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:WINEDLLOVERRIDES="winemenubuilder="
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:PYTHONPATH="/usr/lib/lutris:/usr/games:/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages"
DEBUG    2023-10-11 23:39:35,445 [command.start:141]:LUTRIS_GAME_UUID="abe38207-e385-4b1b-ad1a-a5b34912458c"
Started initial process 103570 from /home/bl4ckk/.local/share/lutris/runtime/winetricks/winetricks --unattended corefonts
WINEPREFIX INFO:
Drive C: totale 12
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 23:26 .
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 23:26 ..
drwxrwxr-x 3 bl4ckk bl4ckk 4096 ott 11 23:26 users
Registry info:
DEBUG    2023-10-11 23:39:35,946 [command.on_stop:195]:Process 103566 has terminated with code 256
DEBUG    2023-10-11 23:39:36,454 [commands._monitor_task:449]:Return code: 256
ERROR    2023-10-11 23:39:36,455 [errors.__init__:18]:Command exited with code 256
None
Buuut...
bl4ckk@bl4ckk:~$ wine --version
wine-8.0.2
Wait, it's not EA but Epic Games. Anyway as shown above it did create the folder after a long time, but it gave the wine version error.
Well, I think it will just be quicker to take a backup and reinstall Zorin from scratch..
Well, it worked. I have just installed timeshift (nobody knows what can happen next) and epic games installation went successfully. I was also able to install League of Legends, which previously, I wasn't.
The actual wine version: wine-6.0.3
