I am new to Zorin, think its is great. Only issue is getting access to my internal camera for zoom. Can anyone help?
Try the solution posted here:
And if you want to be secure, use https://meet.jit.si instead of zoom - I refuse to use zoom after they lied about end-to-end encryption at launch.
I never touch anything that has been lied about - also with jitsi, no need to install any application - all you need is a browser that supports chrome extensions - and you can link meetings to Google calendar or Outlook calendar. Encryption needs to be turned on and if you do you can't record sessions, only if encryption is off.
