Hi and welcome.
As Zorin 17.x is based on Ubuntu 22.04 I used this as the criteria for a Brave A.I. search via Mojeek which brought back the following:
Keyboard Not Working Ubuntu 22.04 MacBook Air T2
Users encountering issues with their keyboard not working in BIOS or after suspending their system in Ubuntu 22.04 on a MacBook Air with a T2 chip can try several troubleshooting steps. One approach involves ensuring that the correct firmware is installed for Wi-Fi and Bluetooth by downloading and running the firmware.sh script from a specific GitHub repository before installing Ubuntu. This script helps pull necessary drivers for these components over to the Linux side.
Another potential solution is to modify the /etc/default/grub file by setting the GRUB_CMDLINE_LINUX_DEFAULT variable to "quiet splash atkbd.reset" and updating the grub configuration with sudo update-grub , as suggested in a Quora post.
This modification aims to reset the keyboard upon resume from suspend.
If these methods do not resolve the issue, users might consider checking if the problem is related to a specific kernel version. For instance, a user reported that reverting to an older kernel version solved their keyboard issues after a kernel upgrade.
To revert to an earlier kernel, users can follow the instructions provided in the context to adjust the grub configuration accordingly.
In summary, addressing keyboard issues in Ubuntu 22.04 on a MacBook Air with a T2 chip involves ensuring proper firmware installation, adjusting grub settings, and possibly reverting to an older kernel version.
Keyboard doesn't work after suspend in Ubuntu 22.04 LTS - Ask Ubuntu
](https://askubuntu.com/questions/1510265/keyboard-doesnt-work-after-suspend-in-ubuntu-22-04-lts)[
answers.launchpad.net
Question #809126 “Keyboard not working after Ubuntu 22.04.04 ker...” : Questions : Ubuntu
](https://answers.launchpad.net/ubuntu/+question/809126)[
unix.stackexchange.com
ubuntu - Keyboard isn't detected on boot, but works after suspend - Unix & Linux Stack Exchange
](https://unix.stackexchange.com/questions/603594/keyboard-isnt-detected-on-boot-but-works-after-suspend)[
askubuntu.com
Keyboard not working after suspend on Ubuntu 22.04 - Ask Ubuntu
](https://askubuntu.com/questions/1418676/keyboard-not-working-after-suspend-on-ubuntu-22-04)[
help.ubuntu.com
Why does my computer not turn back on after I suspended it?
](Why does my computer not turn back on after I suspended it?)[
reddit.com
r/Ubuntu on Reddit: Wi-Fi, keyboard and Trackpad not working MacBook Air 2029 ubuntu 20.04
](https://www.reddit.com/r/Ubuntu/comments/13hj2ah/wifi_keyboard_and_trackpad_not_working_macbook/)[
bugs.launchpad.net
Bug #2008774 “Ubuntu 22.04 not waking up after second suspend” ...
](Bug #2008774 “Ubuntu 22.04 not waking up after second suspend” : Bugs : linux-signed-hwe-5.19 package : Ubuntu)[
quora.com
How to fix a keyboard not working after suspend in Ubuntu - Quora
](https://www.quora.com/How-do-I-fix-a-keyboard-not-working-after-suspend-in-Ubuntu)[
superuser.com
keyboard - Issues on a MacBook Air 2020 T2 w/Ubuntu 24.04.1 LTS - Super User
](https://superuser.com/questions/1856687/issues-on-a-macbook-air-2020-t2-w-ubuntu-24-04-1-lts)[
askubuntu.com
updates - Ubuntu 20.04 - keyboard not working - Ask Ubuntu
](https://askubuntu.com/questions/1274890/ubuntu-20-04-keyboard-not-working)[
github.com
Keyboard and touchpad not working after suspend · Issue #399 · pop-os/pop
](Keyboard and touchpad not working after suspend · Issue #399 · pop-os/pop · GitHub)[
forums.linuxmint.com
Keyboard stops working after suspend so
](https://forums.linuxmint.com/viewtopic.php?t=362999)
