Hi!
I'm trying my best to get Zorin to work at its best. The machine I have is a MacBook Pro (17" mid 2010). The battery is 2 years old. However, the charge when I was working with Catalina would go all the way to 100% and last for about 3hs... Now it lasts only 1 hr and it has a cap at 32%. I have installed Slimbook Battery to inspect and conserve energy. This is a screenshot of what is happening.
- How do I install Dynamic Battery?
- How do I configure the TLP-UI?
- Do I have to uninstall Slimbook Battery?
Is not needed anymore....
(Just for information it is a gnome extension that can be installed from extensions.gnome.org)
You can launch TLP-UI from application menu and configure it from there.
I don't really know but it is better to uninstall it to avoid conflict between the two apps.
Have you done any full discharge, full charge cycles to calibrate battery meter?
