Macbook Pro 2020 2 Thunderbolt 3 ports no audio
Well hello,
since my macbook is getting a bit slugish, I wanted to test if its the 6 years old Hardware, or a lack of optimisation from Apple to "encourage" me to buy a new M-Series Laptop.
Well - as the title says - I am stuck at getting the audio working. I only have the dummy output available. I already followed the T2 Help article, but that didnt solve the issue.
I got mouse, keyboard, Bluetooth and Wifi working so far, its really just the audio missing. Anyone an idea how I should continue from here?
Hi, I would take a look here:
https://9to5linux.com/how-to-fix-dummy-output-no-sound-issue-on-macbook-computers-running-linux
Found that too. Unfortunately I don’t even get that far. I only get an entry for the Intel Kabylake HDMI
Your Apple doesn't have an M-Chip, right?
Hi. What are the results of
sudo lshw -C multimedia
It's an 8th Gen Intel i5 Macbook.
Here is the output
 *-multimedia
       description: Multimedia audio controller
       product: Apple Audio Device
       vendor: Apple Inc.
       physical id: 0.3
       bus info: pci@0000:02:00.3
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=t2bce_audio latency=0
       resources: irq:0 memory:b0c00000-b0ffffff memory:b1180000-b11fffff memory:b1230000-b123ffff
  *-multimedia
       description: Audio device
       product: Cannon Point-LP High Definition Audio Controller
       vendor: Intel Corporation
       physical id: 1f.3
       bus info: pci@0000:00:1f.3
       logical name: card1
       logical name: /dev/snd/controlC1
       logical name: /dev/snd/hwC1D2
       logical name: /dev/snd/pcmC1D3p
       logical name: /dev/snd/pcmC1D7p
       logical name: /dev/snd/pcmC1D8p
       version: 30
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list
       configuration: driver=snd_hda_intel latency=64
       resources: iomemory:400-3ff irq:77 memory:91a10000-91a13fff memory:4000000000-40000fffff
  *-usb:1
       description: Video
       product: FaceTime HD Camera (Built-in)
       vendor: Apple Inc.
       physical id: 2
       bus info: usb@5:2
       version: 2.01
       serial: CC20392E8YNJ3Y37F
       capabilities: usb-2.00
       configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
  *-sound
       description: Audio
       physical id: 3
       logical name: card0
       logical name: /dev/snd/controlC0
       logical name: /dev/snd/pcmC0D0p
       logical name: /dev/snd/pcmC0D1c
       logical name: /dev/snd/pcmC0D2p
       logical name: /dev/snd/pcmC0D3c
       logical name: /dev/snd/pcmC0D4c
       logical name: /dev/snd/pcmC0D4p
I found an entry in search result that suggests:
" * Driver Selection : To force the use of the legacy snd_hda_intel driver instead of SOF (which may be required for HDMI audio or specific hardware compatibility), add the following line to /etc/modprobe.d/intel-dsp.conf (or 00-sound.conf ):
options snd-intel-dspcfg dsp_driver=1
To edit:
sudo nano /etc/modprobe.d/intel-dsp.conf
Add the line starting options, then Ctrl+ O to write out the changes, press Enter key, then Ctrl+ X to exit, reboot and see if you have sound.
Keep us posted.
I don't seem to have either of those .conf files present.
/etc/modprobe.d$ dir
alsa-base.conf			blacklist-oss.conf
amd64-microcode-blacklist.conf	blacklist-rare-network.conf
blacklist-ath_pci.conf		disable-algif_aead.conf
blacklist.conf			intel-microcode-blacklist.conf
blacklist-firewire.conf		iwlwifi.conf
blacklist-framebuffer.conf	zorin-blacklist-ntfs3.conf
blacklist-modem.conf
Edit: I did add that options into the alsa-base.conf, but that didn't do anything, neither
OK. Can you please run this to get the hex code ID of the card please:
lspci -vvnn | grep -A 10 -i audio
00:1f.3 Audio device [0403]: Intel Corporation Cannon Point-LP High Definition Audio Controller [8086:9dc8] (rev 30)
	Subsystem: Intel Corporation Cannon Point-LP High Definition Audio Controller [8086:7270]
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64, Cache Line Size: 256 bytes
	Interrupt: pin A routed to IRQ 77
	IOMMU group: 9
	Region 0: Memory at 91a10000 (64-bit, non-prefetchable) [size=16K]
	Region 4: Memory at 4000000000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
		Status: D3 NoSoftRst+ PME-Enable+ DSel=0 DScale=0 PME-
02:00.3 Multimedia audio controller [0401]: Apple Inc. Apple Audio Device [106b:1803] (rev 01)
	Subsystem: Apple Inc. Apple Audio Device [106b:188a]
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0, Cache Line Size: 256 bytes
	IOMMU group: 18
	Region 0: Memory at b0c00000 (64-bit, prefetchable) [size=4M]
	Region 2: Memory at b1180000 (64-bit, prefetchable) [size=512K]
	Region 4: Memory at b1230000 (64-bit, prefetchable) [size=64K]
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Kernel driver in use: t2bce_audio
	Kernel modules: t2bce_audio
03:00.0 PCI bridge [0604]: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] [8086:15ea] (rev 06) (prog-if 00 [Normal decode])
	Subsystem: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] [8086:0000]
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 16
	IOMMU group: 11
	Bus: primary=03, secondary=04, subordinate=78, sec-latency=0
	I/O behind bridge: 4000-7fff [size=16K] [16-bit]
sidenote: All solution I could find so far are for older Macbooks or the bigger ones. Wonder if I am amongst the first ones to actually try to get this working at this point...
HI, it appears that there is no driver unless it matches one of the models in the search result I found below, needing an out-of-tree driver:
"However, partial functionality is available for specific Apple models (such as the MacBook Pro 13-inch 2020 and MacBook Pro 15,1 ) through the community-driven t2linux project. This involves using an out-of-tree driver called apple-bce .
Key details regarding the driver status:
  • Driver Name : apple-bce
  • Status : Partial . It generally supports audio playback only ; recording (microphone) is typically not supported.
  • Requirements : The T2 Bridge Controller (106b:1801 ) must be active, and IOMMU must be enabled in the system BIOS/UEFI.
  • Availability : This driver is not included in mainline Linux kernels (up to version 7.1+ as of recent probes) and requires manual installation or use of a patched kernel from the t2linux community.
Source materials:
https://search.brave.com/ask?q=How+do+I+install+the+apple-bce+driver%3F&source=llmFollowup&conversation=09a73c4b4e48e96716489aa7a8834127e72b
Alright, I got it working now. I will admit, I worked on this issue with Copilot in the background, till the point copilot threw in the towel. But the prompt you put in Brave AI has put some new ideas in the Copilot AI.
The issue was not the driver, but pipewire/wireplumper not creating any audio sinks for the cards, as it apparently just ignored the profiles.
So here is a (AI generated) summary of what the issue actually was and how it was solved in my case:
Symptoms
After installing the T2 kernel and T2 support packages:
  • Keyboard works
  • Trackpad works
  • Wi-Fi works
  • Bluetooth works
  • Apple T2 Audio devices appear in ALSA
  • GNOME only shows "Dummy Output"
  • No sound is available
Diagnostic results
The T2 audio driver was already loaded correctly
lsmod | grep t2bce
showed
t2bce_audio
t2bce_vhci
t2bce_core
t2bce_dma
The Apple T2 audio hardware was detected correctly:
aplay -L
showed
Apple T2 Audio, Speaker
Apple T2 Audio, Digital Mic
Apple T2 Audio, Codec Output
Direct ALSA playback already worked:
aplay -D sysdefault:Audio /usr/share/sounds/alsa/Front_Center.wav
This proved that:
  • the T2 driver was working
  • the speakers were working
  • ALSA was working
The problem was therefore not a driver issue.
The actual problem
PipeWire/WirePlumber detected the card but left it disabled.
pactl list cards
showed
Active Profile: off
and
wpctl status
showed
Dummy Output
No audio sinks were created.
Fix
Enable the Pro Audio profile manually:
pactl set-card-profile alsa_card.pci-0000_02_00.3 pro-audio
Immediately afterwards:
wpctl status
changed to:
Apple Audio Device Pro
Apple Audio Device Pro 2
Apple Audio Device Pro 4
Audio started working instantly, including browser playback.
