Hi i had a set of macos big sur theme and icons that worked for Zorin 15.3 beautifully. When i upgraded to Zorin 16 pro, it seems the themes are not compatible with Zorin 16 pro. does anyone have a link where i can download them that work for Zorin 16 pro?
That's the look - I still have the WinOS-type bottom bar, running Zorin lite (not sure where to find build, total noob). How did you get that to configure?
Well. Firstly you need to change Zorin Aparance in the ubuntu style so you dont get Win type bottom bar. After that you can install Plank(sudo apt install plank) and start it with plank command. (You should setup plank for start when you PC is starting it) for install Whitesur theme i just used @FrenchPress link. You can also found MacOS plank theme in the internet somewhere.
While this is true, nhart99 said they are using Zorin Lite.
That's XFCE.
Plank would work and is an option, but the XFCE panel is very easy to customize as is and can replicate that look in your screenshot no problem.
