While this issue is not specific to Zorin OS, I am using it now so I will mention it here. I need to use screen magnification on my device due to my vision. I sometimes need to take screen recordings or screenshots; however, when I try to a take screen recording or a screenshot, it shows the desktop zoomed in. It is not good since I assume the general audience will not appreciate a zoomed content. Is there anyway I can change that behavior. I am open to use an alternative magnification tool; however, I need it to be integrated with the system and I must be able use keyboard or keyboard+scroll shortcuts to change zoom level dynamically. Does anyone have a solution for me?
When You go to Settings>Accessability, you have there a Magnification Option what you can turn on and set up. Do You use that and if yes: How do You have set that up?
