The system icons integrate nicely with the theme, but custom icons don't.
The 2 on the left stay white, while the others change color based on the theme
Is there a way to maybe choose an icon from the default ones for every icon in the tray so they integrate nicely?
I think it's possible to change the icons, so I was thinking of making icons all in the same color. They won't match the system icons, but at least match each other.
But having them change along with the system icons would be better.
The icons in question are the Symbolic icons located in the "symbolic" directory in each Icon Sets folder in /usr/share/icons/... or user applied ~/.icons/...
Symbolic icons tend to be monochromatic in light or dark and very basic with details.
Many applications will call on the symbolic icons for the tray or other locations that display icons in a very small or harder to see format.
There are a few that instead supply their own icon in a folder contained within that applications own directories - but not many apps do this.
And these Programs: Are these Flatpaks/Snap's or .deb's? Because Flatpaks/Snap's can be a bit tricky because there are running in Containers. And so there have only limited Permissions.
Apps installed with APT should show in /usr/share/icons/hicolor/apps but you may need to explore hicolor a bit. Often, an icon specifically for use in the panel (taskbar) will be labeled with its name_tray
There is some annoying variance... Some apps will instead place their icon in the more general location of /usr/share/pixmaps which is an older practice that lingers.
It can help to use a file searching utility (I use the built in search in Nemo FM) if having trouble locating a tray icon.
For Flatpak, I am not sure.
I would think it would definitely be contained and relegated to the path you show since Flatpak is containerized, it should not place elements elsewhere in Root.
