Make middle button double click
Hello,
I am relatively new to Zorin OS. I have been using Zorin OS 16.1 for almost a month now. And overall I was able to fix most of the initial issues that I had encountered.
One thing that I am stuck on is making my middle mouse button. I want to make middle button behave as double click when I single-click the middle mouse button.
Thank you in advance for any assistance.
Shri
This answer was supplied for 18.04... I do not know if it will work on 20.04.
What I would do is fire up a LiveUSB or a VM of Zorin 16 to test it first.
Slight correction. I am on Zorin OS 16.2. I tried this already. But it's not working :frowning:
The input-mapper package is no longer in the main repository. But the .deb is available as well as the source on Github:
Thanks Aravisian .... Input Remapper installs as per instructions and it found all my input devices all 10 of them ..... haven't played with it yet .... will when I have more time ..... can I assume that both of your downloads are the same program just that the last one is on GitHub ??? .... I used the one on
UbuntuHandbook
Thank you. Will check it out on my VM and confirm if that works.
