Malware and Snap
Just saw this on DistroWatch.com. Thought I'd share. Read on ...
Link: DistroWatch.com: Put the fun back into computing. Use Linux, BSD.
This has to do with malware having been found recently in Snap repositories.
I've heard the arguments for and against Snap packages. I'm "against."
No doubt this news will add credence to anti-Snap folks' arguments against it.
There's a much bigger issue:
Question: If I remove Snap, will this have the effect of removing all listed Snap software in the Software Center? Or will it still show up? If it will still show up, then ... what's the point? If it won't, then okay, great.
When You uninstall Snap you don't get anymore the Snap Version from the Software Store; that is right. You only see the Flatpak and .deb (Zorin) Versions.
P.S.: A Tip for the Uninstallation because @emit didn't wrote it. When you uninstall snapd uninstall the Snap Plugin too. Simply type sudo apt purge snapd gnome-software-plugin-snap
Thank you very much.
I think you misspelled "software."
So it should be:
sudo apt purge snapd gnome-software-plugin snap
Correct?
Sorry. Yes it's software. I changed it. But before you uninstall it, it could be good to type first:
sudo systemctl stop snapd
sudo systemctl disable snapd
OK. Before I do anything, I want to make sure of the sequence of commands I should enter. See below, please ...
snap list
sudo rm -rf /var/cache/snapd
sudo apt-get remove --purge snapd
sudo apt autoremove
Is this correct and the recommended way to do it? Thanks.
Not sure about the placement of the "snap list" command, though.
I personally don't use Snap (I stick with Flatpak and .deb files), so ... OK.
@Ponce-De-Leon @Aravisian
Probably be best to put "snap list" at the beginning ...
OK. New sequence:
snap list (if nothing; proceed - if there are snaps, remove them first)
sudo apt autoremove
Correct? Please advise. Thanks. @Ponce-De-Leon @Aravisian
You can control first if You have any Snap Versions installed, yes. On default there are no Snaps preinstalled. So, when You do this after a fresh Installation theoretically You don't need to do that or when You never installed a Snap Program. But when you want control it, then the Command would be the First:
snap list
After that comes:
I'm not totally sure, but when I remember right, the cache snap File should automatically deleted with the disable command. It should shown You in the Terminal. Only for Just-in-Case you can use the Command sudo rm -rf /var/cache/snapd
After that comes the Uninstallation:
sudo apt autoremove
Or to make it short:
snap list
sudo apt autoremove
Thanks. This is what I will use:
sudo apt purge snapd gnome-software-plugin-snapd
sudo apt autoremove
I got what you said about "disable" and "rm -rf" ...
... but I'll still include "rm -rf" and "purge snapd" ...
... just to be on the safe side and to be thorough ...
I will not include "snap list" because I don't have any.
I'll do it this way and report back shortly. Thanks again.
UPDATE:
It worked. No problems. Rebooted the PC and no more snaps show up. Good riddance to snaps. Why'd they ever become a "thing" ... ? Crazy. The Zorin Group should consider getting rid of snaps in the software center. (But that's just me.)
Snap is a Development from Canonical - the Developer from Ubuntu. And they push it really hard. That is the Reason why I don't like it. I tried it in the Past but I found the Performance not really good. The Opening of A Program was slow and they didn't run smooth.
Linux Mint for Example banned Snap from her Distro. They only offer .deb and Flatpak.
The ZorinGroup does not include any Snaps in Zorin OS by default at this time, but does leave the framework in place so that the user may choose for themselves.
Controversy surrounds Snap. But some users may like it and may want to use it and that is their choice and their right to do on their own machine.
Personally, I agree with the ZorinGroups decision to not make the decision on behalf of the user.
Correct.
You can easily look if snap is installed. Type in the Terminal apt list snapd and when there don't stand that it is installed, it is not installed. But Your Text look like that it is not installed.
For the Plugin I had made a big Mistake that I have corrected. There was a - missing. That is the Reason for:
So, it must be gnome-software-plugin-snap
When You type apt list gnome-software-plugin-snap You will see if it is still installed. If it is installed type sudo apt purge gnome-software-plugin-snap
Yes, it isn't installed. That stands there:
So, it isn't removed because it isn't installed.
And at the list Command above You can see it too:
Behind the plugin Line would be stand that it is installed.
Yes, that shows that it is available in the Repo's. So You know that You can install it.
No Problem. To give You an Example:
I marked it red. That is german but You see how it looks.
