What shortcut or software can I use to manage my clipboard? In Windows 11 it would be equivalent to the "Windows + V" key
i tried different clipboards but settled on copyQ.
works nice much like windows snipping tool.
Snipping tool is more for screenshot selection rather than Clipboard. Personally I find Plasma better than Gnome for this as Clipboard Manager in Plasma is in the System Tray by default.
I'm in love with Pano extension!
https://extensions.gnome.org/extension/5278/pano/
Install it from gnome extensions then install these extra packages on terminal:
sudo apt install gir1.2-gda-5.0 gir1.2-gsound-1.0
on the extension options, you can set the keyboard shortcut you like
you're right, sorry i got confused with another app (ksnip) i use for screenshots .
