I can't get MegaSync to work properly.
-I can't get auto start to work when I restart the OS. I have checked "start on startup" but when i open settings again it's unchecked.
-Only megas folders are visible. I can't choose my home or documents folder.
-It crashes from time to time.
Storm
22 August 2021 08:06
2
Hi,
Have you downloaded the right .deb file (Ubuntu 20.04 for Zorin 16)?
Yep! Is there a preferred way to uninstall and reinstall on zorin? Before os16 I tested os 15 and it worked fine.
Storm
22 August 2021 09:27
4
Not really. Some worship CLI way, other wants a GUI. I use the synaptic to install/uninstall stuff with.
Can you issue this command in terminal and paste the output?
megasync --version
This is the output?
Error unsetting QT_QPA_PLATFORMTHEME vble
MEGAsync v4.5.3 (7c8db8f)
I've been on a trip, sorry for the delay.
That is exactly the same output as mine (on Zorin 16).
I think you can ignore this
part.
The only thing I can think of is to uninstall then re-install.
If you have Gdebi installed, you can do it in GUI.
sudo apt install gdebi
Download the latest Mega desktop app for Ubuntu 20.04 (which Zorin 16 is based on):
Open the downloaded file using Gdebi.
It should give you a choice for uninstall/reinstall/install.
If you desire, you can correct the error using qt5ct.
It only means that the QT based app is not using the gtk theme.
Shaku
11 May 2022 01:40
9
I had installed megasync from the software center and it crashed often. Then I uninstalled it and followed these steps. Thank you very much for your help! Now it works
